05-28-2013 12:25 PM - edited 03-13-2019 08:13 PM
I have reviewed the 9.0 and 9.1 UCM CDR fields and I am under the assumption that UCM registered Jabber client would generate a CDR (at a minimum) after a call is completed?
Also...it there a way of pulling information regarding IM sessions, amount of peer-to-peer, multiparty messages, etc...from UCM?
Any insight would be appreciated...thx.
05-28-2013 01:36 PM
No, CUCM just handles the softphone/deskphone control.
It has nothing to do with IM capabilities on Jabber clients.
You would need to configure the postgreSQL DB for IM&P to store IMs, and then try to get that info from that.
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
05-28-2013 01:39 PM
Jaime, appreciate the response.
