LAN VoIP and AutoQoS
stretchlad
We are looking at deploying 2x4500 switches in the core and 3750's at the edge. We want to configure this ready for a voice system and I have read through the notes. AutoQoS seems like a good solution as it's easy.
Is there anyhting it misses in terms of VoIP?
What about intervlan traffic, is there anything I should configure on the SVI's?
Priority queues guarentee bandwidth but does this mean they also steal bandwidth if the Voice is not being used or can the SRR shared queues also use this bandwidth when it's not in use?
smalkeric
Level 6
Level 6
I don't think Priority queues steal bandwidth if the Voice is not being used
