Lightning Protection for 7965 IP Phones
BethanyTerry
I have recently purchased some ONEAC Convergent SeriesTM lightning protection devices. The packaging says it's designed for 10/100/1000BaseT Ethernet applications, including VoIP phones with PoE. However, when plugged in to these, our phones do not register. Does anyone have any experience using these, or similar, third party protective devices? We really need the extra protection, as this site is prone to lightning strikes. Thanks! -Beth
Rob Huffman
Hi Beth,
Interesting question
Which Model are you using? It looks like only one supports
PoE.
http://www.onpower.com/pdf/917172AConvergentSeries.pdf
Cheers!
Rob
Rob-
I ordered the RM-PELP100. It works great on a non-powered test switch in my office, but when we try to plug it in between our 7965 Ip phones and the 3560 PoE switch - nothing. -Beth
Rob Huffman
Hey Beth,
Did you try any other phone models??(just curious)
I would contact;
For technical assistance on ONEAC products or to place orders for batteries or other spare parts, the customer
may contact ONEAC Technical Support at the following telephone numbers:
For EDP and CP UPSs only:
Toll-free (customer service) 800-239-2257
Fax (customer service) 800-833-6829
For all other ONEAC products:
Toll-free (USA) 800-327-8801, choose Option 3
Telephone (USA) 847-816-6000, ask for Technical Support
Fax (USA) 847-816-0259
E-mail address ts@oneac.com
Telephone (Europe) +44 (0) 2380 610311
Fax (Europe) +44 (0) 2380 610852
Other Contact local distributor or reseller
Cheers!
Rob
Rob-
I was using a 7945 Ip phone when I tested the device using a non-PoE switch. As you know, that worked fine.
I contacted ONEAC customer service, but they were little help. He had to look the device up himself - he was not familiar with the product. I may try to find a tech support line versus customer support. -Beth
