Low Call Duration
ariela_81
I'm receiving calls from a Sonus Softswitch to terminate them, but we have a problem, all the calls don't have more duration than 2:53 minutes, I think there's a timer or something. I have the same configuration (dial peers )for others calls with other prefixes and they don't have problem at all.
Any clue?
Thanks!
ketpatel
Check to see if this calls are in active state or connected state by "show call active voice brief" command. If the calls are not active state the call will be up for 3 min an will get dropped. If you find that the calls are not in active state you need to find out why there is no connect message coming from pstn since you are terminating this calls.
hope that helps..
ketan
Thanks for answer ketan.
I can see the calls in active state but, what can i do to avoid the calls get dropped??
I have another Gateway and it terminate all these calls with any problem and without duration limit.
Ariela
david rangel
same problem over here at min 3 calls get dropped h323 to PSTN, did you find a solution ?
