08-10-2005 11:20 PM - edited 03-13-2019 10:05 AM
Hi, Is there any recomendation to the max number of IP Phones for the Voice vlan. I need to design the ip address scheme for 2000 IP Phones. Can I have them all in a single vlan ?
Brgds
Renzil
08-11-2005 06:46 AM
SRND docs suggest a good rule of thumb is not more than 512. I would not keep the number of devices that high. Usually limiting to a class C is not a bad idea.
Also keeping the vlan local to each wiring closet will help prevent STP changes propagation from one wiring closet to another.
08-11-2005 06:50 AM
You would follow general campus design guidelines irregardless if it was data or voice
See:
cisco.com/go/srnd
under the Campus Design Section:
Under one of those docs, Cisco recommends a 512 limit per vlan
08-11-2005 07:43 AM
We have three different sites where I manage the VoIP network and each site has its own subnet of 192.168.x.x but on each switch we have configured the same vlan for all the phones. I think we use vlan 20 or something. Anyways, we run about 300 phones without a problem. I'm not a networking ace so I'm not sure if it matters that we are using different subnets to the same vlan or not.
Jeff
