395
jim.stengle
Beginner
Maximum Attendant Console Sessions
What is the maximum number of Attendant Console sessions supported by CallManager 4.0 with a two server environment? I have a customer who has requirements for 45 Attedant Consoles. What would having a third CallManager do to the total capacity, would we double the amount?
1 REPLY 1
Daniel Baum
Jim, this depends on the server model and the device weight calculations of the cluster.
Please contact your local Cisco Channel SE, Cisco SE and/or Cisco AVVID Certified Reseller, and have them run through with you your device weights and server models to determine the quantity.
Mention: Cisco CallManager Capacity Tool
With CallManager 4.0, the AC quantity is much greater than previous releases:
http://www.cisco.com/en/US/products/sw/voicesw/ps555/products_data_sheet09186a00801f8e1c.html
Cisco CallManager Attendant Console 1.3 ships with each Cisco CallManager 4.01 application
Scalability
Two hundred Cisco CallManager attendant consoles per cluster
Up to 600 total hunt-group members divided in as many as 150 hunt groups (pilot numbers) per Cisco CallManager cluster
Up to 128 hunt-group members per hunt group
Four hunting algorithms: Longest Idle, First Available, Circular, and Broadcast
Ability to queue up to 32 calls (on hold) to a pilot point
As many call loops per attendant console as lines are configured on the controlled IP phone device—Any loop may be assignable as a hunt-group member
Maximum of 512 simultaneous calls on as many as 200 configured attendant consoles
Dan
Create
Recognize Your Peers
Content for Community-Ad
