07-12-2006 06:44 AM - edited 03-13-2019 02:09 PM
I am about to install CCM on MCS-7825-H2-IPC server and received following field notice:
from reading it, it appears that the 2000.4.3a OS resolves the NIC issues, but not the SATA RAID issue, where a manual process is identified.
What is the suggested OS version for that server, using CCM 4.2.
Chris
07-12-2006 07:08 AM
Chris
Isnt 2000.4.3 the only OS disc that supports that hardware ?
07-12-2006 09:02 AM
I was not sure, but I guess I have no choice then and go with the 2000.4.3a and hope the customer never needs to rebuild the RAID array ;-)
Chris
07-12-2006 03:58 PM
Chris,
Check this doc. 7825-H2 only supports 2000.4.3a for new installs.
http://www.cisco.com/en/US/products/hw/voiceapp/ps378/prod_release_note09186a00806a4863.html
