MeetingPlace 8.0 Fresh installation.
strangly
Dear Expert,
Need some help with Fresh installed MeetingPlace. After installation of MeetingPlace Express, i cant login to Web, says username and password incorrect.
Tried 3rd times installation and for sure my password was correct during installation,
Root
mpxadmin
Administrator
is that any setting need to be done before i can access to web login? Appreciate for the help.
Wong Sia King
Natasa Ciric-Bukatarevic
Hi Wong Sia,
For MP 8, to log in to application server GUI, you will need to use "admin" user and the password specified during installation.
If you MP Web server installed, you can log in as any user that is created or imported to the application server.
I hope this helps.
Natasa
