576
Highlighted
Contributor
MGCP CM Primary won't register
Hi all,
I have a new 2851 running 12.3911)T10
1 MFT T1 in the MBRD slot 3
CM 4.1.2 with a publisher and sub
P 10.1.8.16
S 10.1.8.15
I will past the config in here, but here is the issue, the Sub as the Primary will not register even though the Pub is fine. (see "sh ccm" output) I have verified:
--network connectivity
--DNS name and gateway name in CM and router both include "spps.com"
--stipped and re-applied "mgcp" global command
--ran DB Helper to make sure database was replicating
I am all out of ideas on this.
help
sh ccm:
VR01-1930#sh ccm
MGCP Domain Name: VR01-1930.spps.org
Priority Status Host
Primary Down 10.1.8.15
First Backup Registered 10.1.8.16
Second Backup None
Current active Call Manager: 10.1.8.16
Backhaul/Redundant link port: 2428
Failover Interval: 30 seconds
Keepalive Interval: 15 seconds
Last keepalive sent: 14:27:55 DST Jun 23 2006 (elapsed time: 00:00:10)
Last MGCP traffic time: 14:27:55 DST Jun 23 2006 (elapsed time: 00:00:10)
Last failover time: 13:40:55 DST Jun 23 2006 from (10.1.8.15)
Last switchback time: 12:19:15 DST Jun 23 2006 from (10.1.8.16)
Switchback mode: Graceful
MGCP Fallback mode: Not Selected
Last MGCP Fallback start time: None
Last MGCP Fallback end time: None
MGCP Download Tones: Disabled
--More-- Backhaul Link info:
Link Protocol: TCP
Remote Port Number: 2428
Remote IP Address: 10.1.8.16
Current Link State: OPEN
Statistics:
Packets recvd: 0
Recv failures: 0
Packets xmitted: 0
Xmit failures: 0
PRI Ports being backhauled:
Slot 0, port 0
Configuration Error History:
FAX mode: disable
VR01-1930#
SH run vitals:
sh run
Building configuration...
Current configuration : 2487 bytes
version 12.3
hostname VR01-1930
ip domain name spps.org
no ftp-server write-enable
isdn switch-type primary-ni
voice-card 0
no dspfarm
ccm-manager redundant-host 10.1.8.16
ccm-manager mgcp
no ccm-manager fax protocol cisco
ccm-manager music-on-hold
ccm-manager config server 10.1.8.15
controller T1 0/3/0
framing esf
linecode b8zs
pri-group timeslots 1-24 service mgcp
description 1930 Como PRI
interface GigabitEthernet0/0
description Connection to VOICE NET on 1930-Como Switch
ip address 10.1.8.10 255.255.254.0
duplex full
speed 100
interface Serial0/3/0:23
no ip address
isdn incoming-voice voice
isdn bind-l3 ccm-manager
no cdp enable
ip classless
ip route 0.0.0.0 0.0.0.0 10.1.8.1
voice-port 0/3/0:23
mgcp
mgcp call-agent 10.1.8.15 2427 service-type mgcp version 0.1
mgcp dtmf-relay voip codec all mode out-of-band
mgcp rtp unreachable timeout 1000 action notify
mgcp package-capability rtp-package
no mgcp package-capability res-package
mgcp package-capability sst-package
no mgcp package-capability fxr-package
mgcp package-capability pre-package
no mgcp timer receive-rtcp
mgcp sdp simple
mgcp fax t38 inhibit
mgcp rtp payload-type g726r16 static
mgcp bind control source-interface GigabitEthernet0/0
mgcp bind media source-interface GigabitEthernet0/0
mgcp profile default
VR01-1930#
14 REPLIES 14
Highlighted
Beginner
hi,
As mentioned that network connectivity is fine.What abt the phones do the they get registered to PUB.Can you make calls between phones which are connected to seperate CCM.
Can you verfiy the version of softwares running on both the servers.
Highlighted
Try restarting the Callmanager service in Publisher. Also make sure the Database layer service is running.
Any errors related to MGCP or devices on the error log.
Anup
Highlighted
Advisor
In the config you posted, the dial-peer command is missing. Do you have that in the router ?
dial-peer voice 1 pots
service mgcpapp
port 0/3/0:23
Sankar Nair
UC Solutions Architect
Pacific Northwest | CDW
CCIE Collaboration #17135 Emeritus
Highlighted
Beginner
You are missing 2nd backup host name
try with below configuration :
ccm-manager redundant-host 10.1.8.15 10.1.8.16
Let me know if this helps.
Satish.K
Highlighted
Satish,
Thats not required. His pub is .16 and sub is .15. His mgcp call-agent has .15 specified. He has a ccm-manager redundant-host with .16 specified too.
Sankar Nair
Highlighted
Is the dial-peer needed for registration? I had not finished the config b/c the gateway had notr registered.
Also, the phones are all working fine off both CM's as the enviornment is pre-existing.
I did see in DBHelper that the Pub DNS is listed as CCM1.spps.org while the Sub is listed simply as CCM2
however
When I look at the box itself they both have the spps.org defined in the fully qualified domain extension (both are in a simple workgroup named WORKGROUP) so I'm not sure why DBHelper is reporting it differently. I do get green smilies though, not Mr. YUK's SO I don't know if this is really a problem, but considering how MGCP reacts with not ergistering on domain name mismatches AND the Sub is the one listed with out the spps.org, it might have something to do with it.
I am simply adding a new gateway so I can get rid of the existing H323 T1 gateway. So all phones and calls work fine right now. This gateway is not in the equation yet.
I asked the client to restart his Sub at the end of the day friday to see if that would fix the issue. I thought it might be a service on one of the servers, but wasn't sure which service would affect MGCP registration. The Pub must be ok since it registers but the Sub does not (see "sh ccm" output)
great feedback so far guys, I hope this extra info sparks some ideas. I'll be opening a TAC case on Monday, but I'd like to get it resolved before having to do that. It's such a basic set-up that it is frustrating the heck out of me to see the Sub listed as "Down" in the Gateway.
Highlighted
Joshua,
YOu are right, you dont need the dial peer for the gateway to register with Callmanager. That is confirmed.
Sankar Nair
Highlighted
One thing I have noticed, is that when configuring mgcp manually (no ccm-manager config) I have needed to add the dial-peer to get it to register initially, but removing it after that caused no issues.
Its very strange. Anyway, I was just curious to see if anyone else has experienced this.
Again, I stress that IT IS NOT NEEDED as shanky said, but initially adding it has caused my pri's to register to callmanager immediately (and then can be removed after that as MGCP controls the d channel and this is why its not needed for call routing).
adignan - berbee
Highlighted
Andrew,
I tried the same config on an FXO gateway and it registers too without the dial peer..
Sankar Nair
Highlighted
Beginner
I am not sure if you have checked this, but If you have a ip domain name specified, when you add your gateway to CCM you have to specify the domain name.
For ex.
VR01-1930.spps.org
Hope this helps
Highlighted
thank you eloy, I have checked this and tried it both ways in CM and on the gateway.
Added info - I also stripped the gateway config clean and set it all back in to see if having it defined in CM first made any difference. It did not.
Highlighted
Enthusiast
In CCM, is the gateway in a device pool with a CCM group that includes both the pub and sub?
Michael
Highlighted
On the GW, can you enable:
deb mgcp packet
deb ccm events
Then do
conf t
no mgcp - wait a couple of secs for the debugs to stop, then
mgcp
then give a few seconds fo the registration to complete, then do "unde all", and sh ccm ( jsut to confirm it's registered fine)
I'll take a look at the traces to see what they show.
Cheers,
Ray
Highlighted
Wild goose chase......The client had applied MS patches to the subscriber which was causing the services to flake out. We uninstalled the patches and everything came up fine.
Thanks for all your help.
Content for Community-Ad
