MGCP controlled PRI gateway will not work with T.38 enabled
bascheew
We have a customer that needs to enable T.38 on their MGCP controlled gateway with PRI.  When we enable T.38 with the following commands, the PRI starts acting very strange.  For example a single inbound call will show up as about 10 attempted calls in q931 debugs, and no calls can go through until we remove the T.38 commands.
Router(config)# no mgcp fax t38 inhibit
Router(config)# mgcp package-capability fxr-package
Router(config)# mgcp default-package fxr-package
Any ideas?
Sudhakar Sharma
Please provide the call manager version. and logs for following debugs for failed call
- debug isdn q931
- debug mgcp packets
Manish Gogna
Can you check if your IOS and running config is not suspect to the following bug
https://tools.cisco.com/bugsearch/bug/CSCta55752
MGCP gateway unable to interpet SDP format when T.38 "and" V150 present
If yes, try upgrading to an IOS with the fix.
Manish
Sudhakar Sharma
- debug isdn q931
