MGCP E1 PSTN problem
wesleyv
I have a problem where I can only dial certain PSTN numbers. Basically I can just phone the PSTN numbers that are directly connected to the PSTN exchange where the IPT E1's terminate.
I got two isdn q931 traces (one that worked, and one that doesn't). I get the following message on the failed call... Cause i = 0x829C - Invalid number format (incomplete number). I think it's because the PSTN doesn't know how to route these calls, any thoughts on this one?
Working one
*Mar 2 06:31:07.040: ISDN Se2/0:15 Q931: TX -> SETUP pd = 8 callref = 0x019E
Bearer Capability i = 0x8090A3
Standard = CCITT
Transer Capability = Speech
Transfer Mode = Circuit
Transfer Rate = 64 kbit/s
Channel ID i = 0xA9839F
Exclusive, Channel 31
Display i = 'Abebe Amare'
Calling Party Number i = 0x0181, '7501'
Plan:ISDN, Type:Unknown
Called Party Number i = 0x80, '01293469'
Plan:Unknown, Type:Unknown
*Mar 2 06:31:07.064: ISDN Se2/0:15 Q931: RX <- STATUS pd = 8 callref = 0x819E
Cause i = 0x82E328 - Information element not implemented
Call State i = 0x01
*Mar 2 06:31:07.076: ISDN Se2/0:15 Q931: RX <- CALL_PROC pd = 8 callref = 0x819E
*Mar 2 06:31:07.324: ISDN Se2/0:15 Q931: RX <- ALERTING pd = 8 callref = 0x819E
Progress Ind i = 0x8488 - In-band info or appropriate now available
Progress Ind i = 0x8482 - Destination address is non-ISDN
*Mar 2 06:31:09.060: ISDN Se2/0:15 Q931: TX -> DISCONNECT pd = 8 callref = 0x019E
Cause i = 0x8090 - Normal call clearing
*Mar 2 06:31:09.088: ISDN Se2/0:15 Q931: RX <- RELEASE pd = 8 callref = 0x819E
*Mar 2 06:31:09.096: ISDN Se2/0:15 Q931: TX -> RELEASE_COMP pd = 8 callref = 0x019E
Broken one
*Mar 2 06:34:37.704: ISDN Se2/0:15 Q931: TX -> SETUP pd = 8 callref = 0x01A3
Standard = CCITT
Called Party Number i = 0x80, '01450581'
*Mar 2 06:34:37.732: ISDN Se2/0:15 Q931: RX <- STATUS pd = 8 callref = 0x81A3
Call State i = 0x01
*Mar 2 06:34:37.732: ISDN Se2/0:15 Q931: RX <- CALL_PROC pd = 8 callref = 0x81A3
*Mar 2 06:34:37.760: ISDN Se2/0:15 Q931: RX <- DISCONNECT pd = 8 callref = 0x81A3
Progress Ind i = 0x8288 - In-band info or appropriate now available
*Mar 2 06:34:40.592: ISDN Se2/0:15 Q931: TX -> RELEASE pd = 8 callref = 0x01A3
*Mar 2 06:34:40.612: ISDN Se2/0:15 Q931: RX <- RELEASE_COMP pd = 8 callref = 0x81A3
gogasca
Level 10
Level 10
Check this error:
I believe you can contact your Telco to verify why is not allowing Called Party Number i = 0x80, '01450581' to be dialed, maybe they requiere something in the Plan or Type
You can force the Plan and Type to be
ISDN and National in the Gateway configuration page in CCM admin.
Seems to be that CallManager option is set (default option)
