MGCP gateway load balancing - how ??
kiplingt
Ive currently trying to load balance between two (or more) MGCP E1 gatways (on a 8 port 6608 card installed in a Cat 6509).
The two gateways are currently in priority order in the route list on CCM, so the first circuit fills up before starting to use the second circuit.
My question is how do you get CCM to load balance between the available channels on multible E1's so they get equaly used???. Is it possable ?
Thanks for any help.
s-doyle
Level 3
Level 3
I am not sure of loadbalancing on the Gateways. I have some useful links which may lead you to such configurations.
Configuring Gateways
http://www.cisco.com/en/US/products/sw/voicesw/ps556/products_administration_guide_chapter09186a00800c2fa9.html
Configuring route lists :
http://www.cisco.com/en/US/products/sw/voicesw/ps556/products_administration_guide_chapter09186a00800c4a1c.html
