MGCP Registration in CallManager without PRI connected to PSTN
baronwright
I have a 2811 gateway with vwic-2mftt1 parired to CCM 4.13sr2. The solution is being built in my lab and I do not have a PRI pstn connection as of yet. The gateways IP address is showing up in callmanager but it is not showing as registered in callmanager. The show ccm-manager on the gateway does show as registered. I am using the config server commands and show mgcp is successfully downloading the config. Call agent is right too.
could the non-registration in call amanger be because the PRI is not up and the dchannel is not active? I have checked the config several times and it looks right.
Hin Lee
If you are not connected, the gateway won't register. I think you can connect two vwic-2mft-t1 with a cross over cable.
Here is a good troubleshooting doc for mgcp
http://www.cisco.com/en/US/products/sw/voicesw/ps556/products_tech_note09186a008017b2ad.shtml
msolak
Level 4
Level 4
the mgcp backhaul messages are only exchanged if the d-channel is active.
the registration will complete if your pri is activated.
greetings
mehmet
How about FXO port?? It is because I preconfigure MGCP for FXO, but FXO hasnt pluged into Telco yet.
I did see IP address at CCM, but not register at all.
Is that apply to FXO too??
Not FXO - they will register w/o connection to telco. The ports should register in mgcp. I had a tough time getting them to register but I think I did a shut/no shut on the voice ports to get them to register. I may have reloaded the rtr too.
One thing to check is to make sure that you set up ccm and voice port to be ground-start or loop-start.
Configuring Cisco CallManager with IOS MGCP Gateways (Analog FXO, FXS Ports)
http://www.cisco.com/en/US/products/sw/voicesw/ps556/products_tech_note09186a008009428e.shtml
Verify and Troubleshoot the Cisco IOS MGCP Gateway
MGCP Gateway Registration Failure with Cisco CallManager
http://www.cisco.com/en/US/products/sw/voicesw/ps556/products_tech_note09186a00805a316c.shtml
