Mobile and Remote Access Requirements on VCS Control - Expressway for EX90
mesut ozcan
Dear all,
I need to deploy MRA on VCS C/E enviroment. My main goal is support EX90s to register internal CUCM via VCS C/E.
CUCM is v10.5 and VCS C/E are x8.6. All this servers are already in use but there is no certificate, DNS or FW configurations for MRA on them.
What is my main requirements?
Is there any exact documents for this goal?
Waiting for all your greatful helps.
Best Regards,
Mesut
7 Replies 7
Terry Cheema
Refer to this doc: http://www.cisco.com/c/dam/en/us/td/docs/telepresence/infrastructure/vcs/config_guide/X8-6/Mobile-Remote-Access-via-VCS-Deployment-Guide-X8-6.pdf
-Terry
Please rate all helpful posts.
Is there any special needs?
I just need to register EX90 to CUCM via MRA.
Do i need IMP servers or DNS records like JAbber deployment?
Mesut
Does anyone have any comment about needing IM&P Server for EX90 - CUCM Registration via VCS C/E?
Best Regards,
Mesut
Can't find any documentation for sure, but I don't think it's required, only CUCM if you just plan on making video calls.
Neither do i.
I guss i will be first one who find out and share if IM&P required or not :)
Best Regards,
Mesut
Hi Mesut,
The EX90 is only connecting to CUCM via Expressway, there is no reliance on IM&P.
mesut ozcan
Any response from Cisco TAC?
Best Regards,
Mesut
