01-02-2017 03:54 AM - edited 03-15-2019 05:37 AM
We have a CUCM and a remote site. Every configuration in CUCM in my opinion is correct.
We have a SIP Trunk configured between the CUCM and the Remote sites VG and a SIP Trunk from the Remote sites VG to the ITSP.
1) MoH is being played between IP phones in the remote site.
2) MoH is being played between IP phones from Central site where CUCM is located and IP phones in remote site and vice versa.
3) MoH is NOT being played between calls made from the remote site to the PSTN through the SIP provider and vice versa.
Can someone help me?
Thank you in advance.
Solved! Go to Solution.
01-02-2017 11:59 PM
With Unicast there isn't much config needed on gateway, just make sure there is an MRGL assigned to gateway added on cucm with MOH server added to it, try resetting the SIP trunk. Also, be aware of the following bug with Unicast MOH with similar symptoms ( try the workaround ).
https://bst.cloudapps.cisco.com/bugsearch/bug/CSCtl21854/?referring_site=bugquickviewredir
Manish
01-02-2017 10:34 PM
Can you verify your MoH related config as per the following doc specific to SIP trunk related MoH issue
http://www.cisco.com/c/en/us/support/docs/unified-communications/unified-border-element/116392-technote-product-00.html
Manish
01-02-2017 11:32 PM
We have Unicast MoH and not multicast.
We have 1 site with H.323 and MoH works fine from or to the BRI PSTN.
We have another site with SIP and we don't have MoH when calls are from or to the ITSP SIP PSTN.
We have G.711 everywhere.
Something that I've noticed is that when I type the command "show voip rtp connections" and MoH is pressed below Remote IP is 0.0.0.0 and when in an active call there is the IP of the IP phone. Shouldn't I see the IP of the CUCM when in MoH?
VoIP RTP active connections :
No. CallId dstCallId LocalRTP RmtRTP LocalIP RemoteIP
1 3041 3045 19316 18118 192.168.61.1 192.168.61.1
2 3042 3043 18118 19316 192.168.61.1 192.168.61.1
3 3043 3042 16830 18318 Local Public IP Remote Public IP
4 3046 3045 16384 0 192.168.61.1 0.0.0.0
Found 4 active RTP connections
01-02-2017 11:59 PM
Manish
01-03-2017 01:16 AM
The configurations in the CUCM with the MRGLs and the MRGs are correct.
I saw that the routers version is "150-1.M4.bin" which is in the listed routers that are affected from the Bug you mentioned.
I disabled "ip cef" from the Router with the "no ip cef" command and MoH just Worked.
Thank you my friend.
01-03-2017 01:35 AM
Good to know that, thanks for updating the post with the resolution.
Manish
