07-26-2004 09:42 PM - edited 03-13-2019 05:47 AM
When listenning to the MOH file internally , it sounds great , but through the eternal gateways ( PSTN ) it sounds bad
Is there something I have to configure and I miss.
Please advice
07-27-2004 06:15 AM
If your gateway is in a g.711 region (the default), the music should sound reasonably good. If your gateway is in a g.729 region (like across your wide area network), music will not sound very good. This is a known property of g.729; you trade off bandwidth for somewhat lesser quality voice and much lesser quality reproduction of music and other non-voice traffic.
This is also a possibility if you've set up Wideband MOH streaming. Wideband is pretty nifty, but we generally don't deploy it for our clients. The reason is that internal calls sound so good that there's a perceptible difference between internal and external calls where you have to shift down to g.711, and that of course starts the users complaining. If you just leave everything toll-quality, the users end up much happier overall.
If you're calling from a cell phone, keep in mind that the codecs they use are generally lower bandwidth (and thus quality) than g.711. Music on hold will never sound good on a cell phone.
07-28-2004 10:34 PM
Thanks Jasyoung
Your answer is so helpful
Really Ia suing the default G.711 and i noticed that as you said it is only the cell phones who has lower quality .
But I never noticed that before in legacy PBXs , why that happen now , any advices .
