MWI issues Unity Connection--Call Manager--Nortel Integration
rmckerrall1
I have recently set up Unity Connection voicemail boxes for phones on an M1:
Nortel---QSIG---Call Manager---Unity connection
Everything works fine except the MWI on the nortel sets.
Is there any specific configuration that is required on the CCM/UC to make this work?
I believe all parameters are set correctly on the M1
Rob
mchondo
From the Cisco side.
Are you able to dial the message indicator and message cancellation numbers that reside on the Nortel to light up the message light on whatever extension your testing it on.
I have been told that the nortel is not using MWI ON/OFF numbers. I dont really understand the nortel side of the setup.
Below is what Cisco is sending accross the QSIG trunk to the Nortel. 8680 is the extension we are trying to light.
Nov 23 10:25:08.320 mst: ISDN Se0/0/0:23 Q931: TX -> RELEASE_COMP pd = 8  callref = 0x0065
CPC-GNAB-03UC01#
Nov 23 10:25:13.348 mst: ISDN Se0/0/0:23 Q931: TX -> SETUP pd = 8  callref = 0x0066
        Sending Complete
        Bearer Capability i = 0xA880
                Standard = ISO/IEC
                Transfer Capability = Unrestricted Digital
                Transfer Mode = Circuit
                Transfer Rate = Packet - not specified
        Channel ID i = 0xAC
                Exclusive, Channel 38
        Facility i = 0x9FAA06800100820100A11B0202F0D3060528F9120050300EA5090A01001204383638300A0120
        Calling Party Number i = 0x2181, N/A
                Plan:ISDN, Type:National
        Called Party Number i = 0xA1, '8680'
Nov 23 10:25:13.472 mst: ISDN Se0/0/0:23 Q931: RX <- CALL_PROC pd = 8  callref = 0x8066
        Channel ID i = 0xAC
                Exclusive, Channel 24
CPC-GNAB-03UC01#
Nov 23 10:25:13.480 mst: ISDN Se0/0/0:23 Q931: RX <- RELEASE pd = 8  callref = 0x8066
        Cause i = 0x8190 - Normal call clearing
        Facility i = 0x9FAA06800100820100A4070202F0D3810101
Nov 23 10:25:13.488 mst: ISDN Se0/0/0:23 Q931: TX -> RELEASE_COMP pd = 8  callref = 0x0066
CPC-GNAB-03UC01#
Hi Rob,
We use PIMG's for our integration between CUC and Nortel so I can't give
you any great ideas here, but I thought this thread did have some some really
good detail and debugs;
http://www.tek-tips.com/viewthread.cfm?qid=1653870
Cheers!
Rob
