Need to add redundancy PRI line for existing network
narasimhateja
We have an existing setup for voice with single PRI line, now we are looking into PRI redundancy, so we purchased another PRI connection from different service provider.., please tell me the configuration for terminating 2nd PRI line on same CUBE and how to make one PRI line as primary & another as secondary..
Thanks in Advance..
Theja
Jaime Valencia
All your questions depends on the protocol to be used (which you don't mention), if you already have a PRI... why don't you look at it as a sample config???????
All your other questions, they depend on what you want to use, and there's already plenty information on cisco.com and threads on CSC on the topic, have you reviewed any of that???
You simple need to search on cisco.com (or google) how to configure MGCP, OR H.323, OR SIP
java
if this helps, please rate
I need to add one more PRI for redundancy purpose, so how to configure two PRI lines on same CUBE
Theja
