Need to block incoming calls from particular numbers on CUCM 10.5
fms000001
Hi Experts,
Can we block incoming call form specific number or can we route the call to voicemail?
Scenario is If I am receiving the call from suppose (012)-(3456789) extension, then is it possible to block only above number?
Here we need to block only 3456789 extension while 012 std code will still be allowed.
Please help if we can do so.
7 Replies 7
Jitender Bhandari
See bellow, on how to block call based on ANI.
https://supportforums.cisco.com/document/71966/blocking-calls-based-calling-party-id
(Rate if it helps)
JB
Ratheesh Kumar
One more link for you
http://www.netcraftsmen.com/cisco-cucm-blocking-calls-by-calling-party-number-id/
     I configured the CUCM as the documentation explain, but the call is not blocked.
     There is any other CUCM parameter that can change the "Route Next Hop By Calling Party Number" function?
____
I created:
PT-incoming-blacklist Inbound calls
PT-BlackList Partition for Black List numbers
CSS:
CSS-H9J-BR-BLACKLIST
PT-BLACKLIST
CSS-H9J-BR-GATEWAY-FORBLACKLIST
Fist translation for incoming calls:
"!" - Partition - PT-incoming-blacklist
CSS: CSS-H9J-BR-BLACKLIST
Route Next Hop By Calling Party Number-Checked
Translation for non bloqued numbers
"!" - PT-Black-List
CSS: CSS-FOR-DNS
Route Next Hop By Calling Party Number-UNChecked
Translation for Block CPN
11!
Partition - PT-BLACKLIST
CSS: none
Block Pattern: Number Changed
But the call always reach the DN and rings.
_______
    Thanks a lot
Did you get this to work? I'm having the same issue. Thanks
For me it worked only if I created TP like \+! instead of just !. I have CUCM 11.5 SU1.
HI Irusanu77,
I tried do this configuration too, but I failed.
You don´t used the ! because this Callmanager version don´t allow start an translation with !, correct?
Best Regards,
DouglasCP
