NM-HD-2VE and NM-HDV2 Question
jmujica
Hi.
I know I can have a VWIC-2MFT-T1 card on the NM-HD-2VE. My question is can I have a T1 port just for Data within the NM-HD-2VE? or it will only support voice configurations? I know the HDV2 can accept Data and Voice Connections as well.
TIA,
-Jose
thisisshanky
Level 11
Level 11
Yes it should support data connections using channel-group command. I doubt if you can still configure both ports on the vwic-2mft-t1 for data. I think only one port can be data..which does meet your requirements..
Sankar Nair
UC Solutions Architect
Pacific Northwest | CDW
CCIE Collaboration #17135 Emeritus
