NO DTMF TONES Passing FXO
j.magee
Beginner
Beginner
I have a FXO port pointed to a DN, say 7000…During the day the call is answered by the operator…After hours the these call are directed to a Call Handler…During the greeting I am unable to say Press 1 in the menu choice…..If I call the Call Handler internally all works just fine….Is there a dial peer statement or something that I am missing?
mcotrone
Participant
Participant
This usually is not an FXO issue, but a DTMF issue depending on the VOIP Signaling you are using (MGCP or H323).
For MGCP verify you have:
mgcp dtmf-relay voip codec all mode out-of-band
For H.323 verify you have on the dial-peer:
dial-peer voice 10 voip
dtmf-relay h245-alphanumeric
I have had this issue when I had a misconfigured MGCP DTMF relay command with Unity.
Mike
Mike,That was the ticket....Thanks Man!!
Recognize Your Peers
