NO ring
tarun.pahuja
Folks,
Tochiba Decade PBX fxs port conneted to a 2610xm cisco router on an FXO port.The router is connected to WAN. On the other end we have 1751V with FXS ports. The problem is that remote users connected to FXS port do not hear a RING when the users at central site call them through the PBX.
If they pick up the phone, they can talk, but NO RING?
if i connect the FXO port at central site to a POTS line, everything works fine.
Anyone had a similar issue?
any suggestions would be highly appreciated.
jtufail
That does sound a bit strange as it should not matter what connection do you have on the central side. When an IP call comes into the 1751 router FXS port should just send enough current to make the ringer on the phone connected to it ring. What happens when you call from one FXS port to another FXS port on the 1751V router?
