no ringback on off-net calls between ccm(4.1) and voice gateway(2600)
johnyoon75
there is something wrong when i try to make a call.
there is no ringback on off-net calls using issue digit "9".
other calls work properly. i can hear ringback tone..
How can i check to resolove this issue?
regards,
john.
thisisshanky
Level 11
Level 11
John,
Have you checked this link ?
http://www.cisco.com/en/US/tech/tk1077/technologies_tech_note09186a0080094c33.shtml
What kind of gateway is this ? H323 ?
Sankar
PS: please remember to rate replies
Sankar Nair
UC Solutions Architect
Pacific Northwest | CDW
CCIE Collaboration #17135 Emeritus
k007
It depends which calls you dont get the ring back tone.
To solve this issue try to put the following command in the dial-peer pots statement
tone ringback alert-no-PI
alternately you can enable the foll. command in the dialpeer voip
progress ind setup enable 3
