05-05-2013 10:35 AM - edited 03-15-2019 05:25 AM
I'm new with JTAPI and i need to place a call betwenn my computer "2100" and a cisco phone "2010", i did that (the cisco phone display "call from 2100") , but the problem is where i pick up i can't hear anything.
please i really really need help, i can't find any solution and i'm loosing a lot of time
thank you
and here's my code :
THE MAKECALL CLASS :
import java.net.*;
import javax.telephony.*;
import javax.telephony.events.*;
import com.cisco.cti.util.Condition;
import com.cisco.jtapi.extensions.*;
import java.util.concurrent.TimeUnit;
import javax.media.*;
import javax.telephony.callcontrol.*;
import javax.telephony.callcontrol.events.*;
import javax.telephony.media.MediaCallObserver;
import javax.telephony.media.events.MediaTermConnDtmfEv;
public class MakeCalll {
final int PORT_NUMBER = 1234;
DatagramSocket socket =new DatagramSocket();
public MakeCalll(String[] args) throws Exception {
CListener listener = new CListener();
final Condition inService = new Condition();
String hostname = "10.10.10.1";
String login = "mourad";
String passwd = "mourad";
String src = "2100";
String dst = "2010";
/* start up JTAPI */
JtapiPeer peer = JtapiPeerFactory.getJtapiPeer(null);
/* connect to the provider */
String providerString = hostname;
providerString += ";login=" + login;
providerString += ";passwd=" + passwd;
Provider provider = peer.getProvider(providerString);
provider.addObserver(listener);
/* wait for it to come into service */
inService.set();
inService.waitTrue();
/* get an object for the calling terminal */
Address srcAddr = (CiscoAddress) provider.getAddress("src");
Terminal srcTerm = srcAddr.getTerminals()[0];
if (srcAddr==null)
throw new Exception("Address not found");
System.out.println("Address: "+srcAddr.toString()+", class: "+srcAddr.getClass().getName());
dstAddr.addObserver(listener);
/*register terminal*/
System.out.println("register terminal");
CiscoMediaTerminal terminal = (CiscoMediaTerminal) srcAddr.getTerminals()[0];
if (terminal==null)
throw new Exception("Terminal not found");
System.out.println("Found terminal: "+terminal.toString());
CiscoMediaCapability[] caps =
new CiscoMediaCapability[]{CiscoMediaCapability.G711_64K_30_MILLISECONDS};
terminal.register(InetAddress.getLocalHost(), 1234, caps);
Address address = terminal.getAddresses()[0];
if (address==null)
System.out.println("Address: "+address.toString());
terminal.addObserver(listener);
srcAddr.addCallObserver(listener);
srcAddr.addCallObserver(new CallObserver() {
public void callChangedEvent (CallEv [] eventList) {
/* ignored */
Call call = (CiscoCall) provider.createCall();
System.out.println("make the call");
call.connect(srcTerm, srcAddr, dst);
terminal.addObserver(new TerminalObserver(){
public void terminalChangedEvent(TermEv[] termevs){
public static void main(String[] args) {
try {
new MakeCalll(args);
} catch (Exception e) {
e.printStackTrace();
} finally {
System.exit(0);
private class CListener implements
ControllerListener, ProviderObserver, CiscoTerminalObserver, CallControlCallObserver,
MediaCallObserver, AddressObserver
private RTPSender conversation;
private CallControlCall call;
public void controllerUpdate(ControllerEvent event)
System.out.println("Controller event: "+event.toString());
public void providerChangedEvent(ProvEv[] events)
System.out.println("Provider events: "+eventsToString(events));
public void terminalChangedEvent(TermEv[] events)
System.out.println("Terminal events: "+eventsToString(events));
for (TermEv event: events)
if (event instanceof CiscoRTPOutputStartedEv)
try {
CiscoRTPOutputStartedEv rtpOutput = (CiscoRTPOutputStartedEv) event;
CiscoRTPOutputProperties props = rtpOutput.getRTPOutputProperties();
if (conversation==null){
conversation = new RTPSender
(props.getRemoteAddress(), props.getRemotePort(),socket);
conversation.setDaemon(true);
conversation.run();
} catch (Exception ex) {
System.out.println("Error streaming");
ex.printStackTrace();
if (event instanceof CiscoRTPInputStartedEv)
CiscoRTPInputStartedEv rtpInput = (CiscoRTPInputStartedEv) event;
System.out.println("streaming audio to url: "+rtpInput.getCiscoRTPHandle());
public void callChangedEvent(CallEv[] events)
System.out.println("Address call events: "+eventsToString(events));
for (CallEv event: events)
if (event instanceof CallCtlConnOfferedEv)
CallCtlConnOfferedEv offEvent = (CallCtlConnOfferedEv)event;
CallControlConnection conn = (CallControlConnection) offEvent.getConnection();
try {
conn.accept();
call = (CallControlCall) event.getCall();
System.out.println("Connection accepted");
System.out.println("Error accepting call");
else if (event instanceof TermConnRingingEv)
try{
((TermConnRingingEv)event).getTerminalConnection().answer();
}catch (Exception e)
System.out.println("Error answer on call");
else if (event instanceof CallCtlConnEstablishedEv)
if (conversation!=null)
conversation.start();
else if (event instanceof MediaTermConnDtmfEv)
System.out.println("DTMF: "+((MediaTermConnDtmfEv)event).getDtmfDigit());
public void addressChangedEvent(AddrEv[] events)
System.out.println("Address events: "+eventsToString(events));
private String eventsToString(Object[] events)
StringBuilder buf = new StringBuilder();
for (Object ev: events)
buf.append(ev.toString()+", ");
return buf.toString();
AND THE RTPSENDER CLASS:
import java.io.File;
import java.io.FileInputStream;
import java.io.FileNotFoundException;
import java.io.IOException;
import java.net.DatagramPacket;
import java.net.DatagramSocket;
import java.net.InetAddress;
import java.nio.MappedByteBuffer;
import java.nio.channels.FileChannel.MapMode;
import java.util.Random;
public class RTPSender extends Thread implements Runnable {
InetAddress farEndAddr;
int farEndPort;
DatagramSocket sock;
public RTPSender(InetAddress addr, int port, DatagramSocket socket){
farEndAddr = addr;
farEndPort = port;
sock = socket;
@Override
public void run() {
System.out.println("run");
MappedByteBuffer fileContent = null;
try
File file = new File ("telsonne.wav");
FileInputStream fin = new FileInputStream(file);
fileContent = fin.getChannel().map(MapMode.READ_ONLY, 0, file.length());
}catch (FileNotFoundException e) {
System.out.println("file not found : " + e.getMessage());
catch (IOException eio) {
System.out.println("io exception " + eio.getMessage());
byte [] buf = new byte[172];
buf[0] = (byte)0x80; //V=2 P(padding)=0 X(extension fields)=0 CC(CSRC count)=0
buf[1] = (byte)0; //M(marker)=0 Payload type = 0 (PCM ULaw)
Random random_generator = new Random();
int sequence_number = random_generator.nextInt(65536);
long timestamp = 1;
int sync_source = random_generator.nextInt();
buf[8] = (byte)(sync_source/16777216);
buf[9] = (byte)((sync_source/65536)%256);
buf[10] = (byte)((sync_source/256)%256);
buf[11] = (byte)(sync_source%256);
long curTime1 = System.currentTimeMillis();
long curTime2 = System.currentTimeMillis();
System.out.println(curTime2);
while (true)
try
buf[2] = (byte)(sequence_number/256);
buf[3] = (byte)(sequence_number%256);
buf[4] = (byte)(timestamp/16777216);
buf[5] = (byte)((timestamp/65536)%256);
buf[6] = (byte)((timestamp/256)%256);
buf[7] = (byte)(timestamp%256);
DatagramPacket packet = new DatagramPacket(buf, 172, farEndAddr, farEndPort);
sock.send(packet);
long ms2Sleep = curTime2 + 20 - System.currentTimeMillis();
curTime2 += 20;
System.out.println("Current Time:"+curTime2+" to sleep:"+ms2Sleep+" ms...");
if (ms2Sleep > 0)
Thread.sleep(ms2Sleep);
sequence_number = (sequence_number+1)&0xFFFF;
timestamp=(timestamp+160)&0xFFFFFFFF;
catch (Exception e){
System.out.println("Exception:"+e);
return;
05-11-2013 04:54 AM
Wrong forum, try developer.cisco.com.
05-15-2013 07:16 AM
it's already did
http://developer.cisco.com/web/jtapi/forums/-/message_boards/message/14953360?p_p_auth=0MbwLKeX
thank you
