02-20-2017 08:35 PM - edited 03-13-2019 09:47 PM
Our scenario is setup B2B SIP URI dial
When SIP inbound dial from 3rd external endpoint via Expressway E&C to Jabber internal, it has some media issue as below:
(1) SIP dial from 3rd external endpoint to Jabber inside (IP address on User-vlan, different vlan with CUCM, Expressway-C vlan) : only audio, not video
(2) SIP dial from 3rd external endpoint to Jabber inside (IP address on VOIP-vlan, same vlan with CUCM, Expressway-C vlan) : both audio and video
There are no firewall between VOIP-vlan and User-vlan
I checked the wireshark logs on Jabber client on Window, it's so weird:
- No.(1) Media traffic exchange between Jabber client (10.161.23.200) and Voice Gateway (10.161.48.10). Attached file wireshark.vlan23.png
- No.(2) Media traffic exchange between Jabber client (10.161.48.240) and Expressway-C (10.161.48.22). Attached file wireshark.vlan48.png
I checked configuration on CUCM side, no SRST applied to Device Pool. It seems CUCM (10.161.48.9) forward media traffic to Voice Gateway.
Thanks for all your answers,
Sy
02-23-2017 04:19 PM
Media flows directly between EXPC and the Jabber.
3rd party external endpoint call reaches eXPC and then EXPC conncts the media directly to jabber after jabber answers.
may be a firewall issue. can you replicate this setup using another laptop/PC ?
show us EXPC logs. so we can have better understanding what is happening there.
02-23-2017 07:54 PM
Sounds like your Jabber implementation has not been configured for 'escalation to multipoint' properly using an MCU or TP server.
02-26-2017 01:51 AM
I found the reason is Device Mobility Infos function. Then I have to create new subnet for Jabber endpoint.
Sy
