Highlighted
Enthusiast
Overhead Paging System via 3660 FXO
CM3.2(2a), 3660 w/ 12.2(2)XT3 w/ FXO port to Bogen ZPM3. H323 configuration something like:
dial-peer voice 20 pots
destination-pattern 200
port 2/0/0
voice-port 2/0/0
timing hookflash-out 50
IP phone dials 200, FXO port status flashes green briefly then disconnects.
I have implemented this type of config successfully at other client locations. Using a butt set directly to the T & R connections yeilds preample tone (in other words it works with an analog device).
I suspect an IOS or CM issue, a TAC case, and lots of debug baloney.
Any help would be appreciated before I go this route.
5 REPLIES 5
Highlighted
Beginner
Re: Overhead Paging System via 3660 FXO
From the manual I read- http://www.bogen.com/pdf/54-5891-03.pdf this can be either loop-start trunk, ground start trunk (either can be FXO), or a station level port (which needs an FXS). Make sure you have the right connections.
Highlighted
Enthusiast
Understood. I have implemented this same config before at other client sites and was looking for something new related to changes in IOS or CM software.
Highlighted
Enthusiast
Brian,
What was the outcome of this problem?  I am in the same situation.
Dan
Highlighted
Beginner
were u able to fix the issue? please put up the solution and gateway config. thanks.
The config on the FXO port is correct.  Verify if you need power or not and you won't be able to tell by looking directly at the paging system.  I would suggest to get a TAM-B w/power supply as you'll need it with your FXO.  This usually solved issues I came across dealing with paging connectivity issues
Content for Community-Ad
FusionCharts will render here
