01-26-2009 02:45 PM - edited 03-13-2019 06:01 PM
I have overlaid DN configured on CME 4 for our 800 number. We added another CME in remote office and PBXs talk over SIP trunk. I need to assign our 800 number to phones on remote office as overlaid DN as well. In other words our 800 needs to ring on phones registered on 2 deferent PBXs. Is it possible?
01-27-2009 05:44 AM
What you want is a forked call.
CME doesn't support that until 4.3 (parallel hunt group), and you may want to investigate if you cold solve the problem better deciding a ringing scheme, you can use CFNA to forward in like in a chain to any destination.
As an alternative, if you want to try it, I've written a "blast" TCL/IVR script that you can use to send call to multiple destinations:
http://pbevila.fastmail.fm/public/bcast.tcl
Note the script is not fully tested, however I coded transfer support in it that is a good thing.
01-27-2009 04:24 PM
thank you. I got easy solution - our 800 provider can forward calls to multiple numbers.
Thanks.
01-28-2009 03:34 PM
Paolo,
Great stuff :)
Chad
