PIX won't pass CallerID info
smebbin
How do I configure the PIX FW to pass on the callerID info to the called party?
jamie.moss
unfortunately you haven't given me much to work on,
what version of the PIX OS are you running?
Are you using NAT?
Is this over a VPN between PIX to PIX, PIX to router / etc..?
Is this a Call Manager Intertrunk Cluster Connection?
We are using Cisco PIX firewalls all over the place and we see all of the caller information with no problems, however there are alot of issues when using Cisco PIX and skinny based connections especially when using NAT (just finished a site using the same setup in the last week).
Look forward to your reply.
We are using PIX OS 6.3. We currently are using NAT.
I apprently misunderstood how the VoIp network is setup. CallerID ifo is being passed to the AS5350 that we use for our gateway to the PRI (Shown by a debug) but, the wrong number shows up on a phone call from the VoIP network to the LAND lines.
