02-01-2002 03:13 PM - edited 03-12-2019 02:17 PM
I have Call Manager setup with H.323 gateway, outbound calls with caller ID works fine, but when someone call inbound, it shows up in missed or received call w/o 9, in order for my users to call without edit outbound, where should i make changes. I read some posting regarding Translation Patterns, but i already have router pattern and calling search spaced defined , if there is simple command on H.323 gate, to make this happen, i would really appriciate it.
thanks
Himmat Vansdadia
02-02-2002 06:15 AM
Himmat,
Have a search on CCO for a document on translation patterns. The translation patterns you want are on the IOS gateway and they can modify the CLI sent to call manager from the router to include the 9.
Don't get confused with translation patterns on the CM.
Paul
02-05-2002 11:23 AM
Here is a sample config:
translation-rule 1 <-----
Rule 1 ^0.% 90
Rule 2 ^1.% 91
Rule 3 ^2.% 92
Rule 4 ^3.% 93
Rule 5 ^4.% 94
Rule 6 ^5.% 95
Rule 7 ^6.% 96
Rule 8 ^7.% 97
Rule 9 ^8.% 98
Rule 10 ^9.% 99
Dial-peer voice 1 voip
Translate outgoing calling 1 <----
Destination-pattern 2...
session target ipv4:192.168.0.100
For more info, checkout the Digit Manipulation section of:
-Dustin
02-07-2002 10:07 AM
Appriciate reply, yes I will go ahead and do that and make changes. Let group know outcome.
thanks
Himmat
02-08-2002 12:21 PM
Thank you all, it worked like a charm.
This is what i did
translation-rule 1
Rule 1 ^0.% 910
Rule 2 ^1.% 911
Rule 3 ^2.% 912
Rule 4 ^3.% 913
Rule 5 ^4.% 914
Rule 6 ^5.% 915
Rule 7 ^6.% 916
Rule 8 ^7.% 917
Rule 9 ^8.% 918
Rule 10 ^9.% 919
dial-peer voice 5 voip
incoming called-number 9
destination-pattern 1...
progress_ind setup enable 3
translate-outgoing calling 1
voice-class codec 1
voice-class h323 1
session target ipv4:10.10.2.5
dtmf-relay h245-alphanumeric
ip precedence 5
no vad
as i wanted to have 91 for outbound dialing.
-Himmat
