3514
degg
Beginner
PRI D-Channel problem
I have a NM-HDV with a VWIC-2MFT-T1-DI, and I just had a partial PRI installed today. I cant get the D-channel to come up. I did a debug isdn q921, and I see
'ISDN Se0/0:23 Q921: User RX <- SABMEp sapi=0 tei=0',
but never a User TX -> show up. does this mean that my controller is not sending SABME packets? I have looked everywhere to find out about how to fix this, but I cant get my controller to Tx. I have checked my config numerous times, my provider has changed channels that we are using, I changed to the other T1 Controller in the card, changed cables, and still no luck. I am using ESF, B8ZS, DMS100, and have verified everything with my provider. Any help?
12 REPLIES 12
rnarayana
Contributor
Is it a h323 or a mgcp gateway.
Also can you please post the configs.
Radhika
williams.jeff
Beginner
What version of IOS and CCM? Is this MGCP or 323?Have you tried going int the controller config and doing shut / no shut?
Jeff
I am using a 3640, 12.3(4)T, with an NM-HDV and a VWIC-2MFT-T1. Controller 3/1 is the one I am using. I have another PRI at a different location with the same provider. The settings are the same, and my provider verified the 2 PRI's are the same on their side. I have checked the config, and I cant see any difference between them. I just never get any User TX SABMEp packets. Here is the conifg.
isdn switch-type primary-dms100
voice call carrier capacity active
ccm-manager mgcp
controller T1 3/0
shutdown
framing esf
crc-threshold 320
linecode b8zs
cablelength short 133
controller T1 3/1
framing esf
crc-threshold 320
clock source line primary
linecode b8zs
pri-group timeslots 13-24 service mgcp
interface Serial3/1:23
no ip address
no logging event link-status
isdn incoming-voice voice
isdn bind-l3 ccm-manager
no cdp enable
voice-port 3/1:23
mgcp
mgcp call-agent 10.50.1.10 service-type mgcp version 1.0
no mgcp timer receive-rtcp
mgcp profile default
dial-peer cor custom
CCM 3.3(3) sr6, MGCP.I have tried shut/no shut, I changed channels being used (with the provider changing as well), I changed cables, I changed slots on the router to a known working one, and I put a loopback plug in and did Cisco's hard loopback test and it passed. But, I still cannot get my controller to acknowledge a RX SAMBE packet, or tx one.
Is there any reason why your are using only 13 channels.Also what is the status of the gateway in callmanager.In MGCP since you are doing PRI backhaul your D channel will not come up till it talks to callmanager.Try to do this.On the gateway put
ccm-manager config
ccm-manager config server
After your put these two reset the gateway from callmanager.This should download the configs from callmanager and register the gateway.Once this is done if you want to use only few channels do the following procedure.
On the gateway use the following command ( this needs to be done after the gateway is register to ccm)
no ccm-manager config
no ccm-manager config server
Then after this
int serial 3/1:23
no isdn bind-l3 ccm-manager
shut
voice-port3/1:23
shut
controller3/1:23
shut
no pri-timeslots 1-24
pri-timeslots 13-24 service mgcp
no shut
voice-port 3/1:23
no shut
int serial3/1:23
no shut
This should bring the dchannel and up .
If you want to busy out the channel is callmanager so that callmanager does not send the calls on 1 to 12 do the following .On the callmanager gateway page "enable status poll" and then go to service parameter and choose callmanager .After the serivce parameter opens choose advanced.In advanced settings under PRI and mgcp choose "channel b-channel maintenance status 1" put the following value = 111111111111000000000000
Thiis should busy out 1 to 12 channels.
I hope this helps.
Radhika
Thanks for all the info, I finally got it up and going. I think it was a isdn switch-type mismatch. I dont think they actually changed it to DMS100, now we are using NI.
mikram
Enthusiast
I have similiar problem, I can only get one T1 PORT working and other stays in deactivated mode. I have changed the cable and channels but i cant assign isdn bind-l3 ccmmanager on D channel.But, when I try both ports with 3640 bootstrap, 11.1(20)AA2, it works fine.
any suggestions.?
thanks
When it is MGCP and you configure such that the router downloads the configs from callmanager ( ccm-manager config command) callmanager sees to it that this command is put in the D channel configs.If your layer 1 is down it is could be a physical layer issue .One more thing could be make sure on the NM-HDV you have any dsps.Again this won't take layer one down.
Radhika
I have 4 DSPs chips in the HDV modules. I have two port MFT1 card, but only one port works. changed cable,nothing seems to bring the layer 1 up. I have swapped the card with new MFT2T2 but no luck
any ideas.
Sascha Monteiro
Frequent Contributor
Is your endpoint configured correctly in the callmanager? The D-channel is backhauled to the callmanager, so he does all signalling.....
But if the ccm doesn't know there is an endpoint, he won't set it up!
check your backhaul
show ccm-manager backhaul
show ccm-manager
debug ccm-manager backhaul
sharka
Beginner
We ran into this cisco bug: CSCef20529
It's not the 3600. But it sounds the same! We could have the provider loop the B channel but we could never ping anything!! Even a loop back to the routers interface, it could not see!! This was the command that we needed to get off the box: network-clock-participate slot 1.. We are using the NM-HDV2 but in a 2600xm. We had seen timing slips as an issue.
Cisco also, changed the card to be E1, reloaded the router, than changed it back to PRI and reload again. This with out the command, kick the card awake!
When I configure Service mgcp with pri-group command, but when I do show run, it dont see it with pri-group command.Also, It does not give me option to bind l3 to ccm-manager, the only option it offers is q931. But, on the otherhand, my second port on T1 card is working fine with mgcp.
any ideas.
thanks
Create
Recognize Your Peers
Content for Community-Ad
