PRI, Facility IE causing calls to drop
travis-dennis_2
Level 7
Level 7
I seem to remember a post a while back where someone was having pronlems with a PRI and the culprit turned out to be Faciltiy IE I think. Does anyone remember this thread and can possible pint me to it?
Thanks in advance!
dperkerson
Not sure about the post but I had this problem. It turned out to be a misconfiguration of the PRI.
Good Luck!
