01-17-2006 11:10 AM - edited 03-15-2019 04:00 AM
I'm trying to determine what ports are in use on my new PRI. I'm running MGCP and don't know how to get this info.
01-17-2006 11:48 AM
You can use for it Performance Monitor on you CCM.
Do the following:
1. Start->Programs->Administrative Tools->Performance
2. In Performance window Add Counters (Ctrl-I)
3. Choose your CCM Server
4. Performace Object choose "Cisco MGCP Gateways"
5. Select counters from list choose "PRIChannelsActive"
6. You can change view to the View Report (Ctrl-R)
I hope that this help.
Wojtek
01-18-2006 05:28 AM
Thanks then I can do some utilization trending.
01-18-2006 06:42 AM
If my post helped you, rate it :-)
Wojtek
01-18-2006 04:53 AM
If you want to check the current port usage on the IOS gateway, do a show voice call summary, which will show you the each port, the active connection and which codec it is using.
01-18-2006 05:34 AM
I tried this command before and it doesn't work on my PRI with MGCP. I have a T1 CAS that works with H.323.
