Problem Booting IP Phone 7941
alicicmirzet
Hallo,
I have tried to reset IP Phone to its default value with the described documents obtained from cisco, but no reset is done and I have the following problem
At the Display it is written "CISCO SYSTEMS"
Line Buttons are blinking one by one and Headset buton is flashing green
Could some one help me to solve the issue
regards,
Just include this command
tftp server flash:term41.default.loads
5 Replies 5
paolo bevilacqua
Hi, the phone will look for term41.default.loads, make sure you have that files and do the reset sequence again.
I have this file in my flash, but I do not get anything.
Line buttons are blinking and Headset button is solid green
regards,
I have done debug tftp events and I receive the message
*Mar 5 14:59:33.595: TFTP: Looking for term41.default.loads
I have the file in flash, but it is not geting it. Here is my config, so you can see what is the couse of the problem
hallo,
I have solved the problem. I repeated the this command several times this day, but id did not work,
After some time I did the command once again and now the phone registers with CME
than
