Problem Dialing from corporate directory
alanc3141592654
Hey All,
We upgraded the IP phones to sccp41.8-4-1sr1s from SCCP41.8-2-1S, and now dialing from the corporate directory does not work.
We just get "the call can not be completed as dialed"
But it works ok from the old firmware phone.
Has anyone experienced a similar issue before?
11 Replies 11
tim.giles
Level 4
Level 4
What version of CallManager is it and what phones are they?
Tim
Hey thanks for the reply. :)
we're running ccm 5.1.1 phones are 7941 and 7961.
Rob Huffman
Hi Alan,
I can't find the exact bug in the 8.4(1)sr1 firmware but it almost surely is. Can you try 8.3(5) on one phone just to test.
Hope this helps!
Rob
Yeah that was my 1st thought as well. I've logged a tac case, So i will see what happens. I'm hoping its not bug, as i don't want roll out firmware for 800 phones agin :(
Bad news ! We've done the same (upgrade to 8.4.1 handset firmware) in preparation for an upgrade to CCM 6.1.2.
Other issues with headset echo and background images making the new 'shadow' font hard to read.
Tried handset firmware 8.3.4 and all seems OK.
Looks like it's rollout time again !!
Forgot to say that the issue is that it is because of the hyphens in the number string.
If you edit the number from 0207-8-xxxxx to 02078xxxxx (i.e a single string) it seems to work OK.
yeah, i logged a call with cisco, and they confirm it to be a bug. Its trying to dial non characters that can't be dialed.. In my case the space.
Apparently this firmware has a few issues. :(
Is there a case number for this bug?
Hey John,
See below, I'm downgrading an earlier version which works fine.
CSCsu43219 Bug Details
en-bloc feature causes non-dialable characters to be dialed
Symptom:
Call fails when phone dials a number with non-dial able characters like - ( ) [].
Conditions:
User directly dials a number from any directory (Missed Calls, Customer
Directory Service) which displays a number with non-dial able characters.
If using "Insert Hyphens in 12-Digit Numbers" CallManager service parameter
any call with 12 digits will create an entry with "-" in the appropriate
directory (Missed, Placed, Received). If user dials directly from any of these
directories the phone will use the en-bloc feature and dial the "-".
Workaround:
-If using custom directory script, edit so non dial able characters are not
displayed.
-Make sure "Insert Hyphens in 12-Digit Numbers" is set to false in 6.1.2
I find it amazing that Cisco STILL trips up at things like this. It's the 21st century and we still get problems like dialling ISO international number formats with a leading '+' or formatted with a '-'.
How do these errors get through QC?
YouTube Ripper, Rip YouTube to iPod, YouTube to MP3, YouTube to MP4, YouTube to PSP, YouTube to 3GP, etc
http://www.youtube-ripper.net/youtube_to_mp3.html">YouTube to MP3,
http://www.youtube-ripper.net/youtube_to_wma.html">YouTube to WMA,
http://www.youtube-ripper.net/youtube_to_wmv.html">YouTube to WMV,
http://www.youtube-ripper.net/youtube_to_mpeg_mpg.html">YouTube to MPG
