10-27-2004 12:41 AM - edited 03-13-2019 06:48 AM
I have a problem with AS5350 and dont understand the nature of what happening with IOS and hardware.
I have following message continuously in log file :
%CSM-1-CSM_UNKNOWN_FAIL_CODE: Unknown fail code 31
Periodically AS5350 stops accept calls and in log file appears following message:
-Process= "AFSapp20", ipl= 0, pid= 191
-Traceback= 604D6F3C 604DA9F4 610D1FC4 610D5070 610D59E4 6111A170 604A54E0 604A54C4
22:24:03: %VTSP-3-VTSP_CALL_DISC_FAILED: VTSP call disconnect failed. channel id 3/0:0:34924, ret -8
22:24:03: %VTSP-3-VTSP_CALL_DISC_FAILED: VTSP call disconnect failed. channel id 2/1:D:34857, ret -8
22:24:10: %SYS-2-CHUNKEXPANDFAIL: Could not expand chunk pool for CCAPI Event po. No memory available
-Process= "Chunk Manager", ipl= 3, pid= 1
-Traceback= 604E6C14
22:24:20: %SYS-2-CHUNKEXPANDFAIL: Could not expand chunk pool for CCAPI Event po. No memory available
22:24:25: %VTSP-3-VTSP_CALL_DISC_FAILED: VTSP call disconnect failed. channel id 3/0:0:33611, ret -8
22:24:31: %SYS-2-CHUNKEXPANDFAIL: Could not expand chunk pool for CCAPI Event po. No memory available
22:24:32: %SYS-2-MALLOCFAIL: Memory allocation of 47200 bytes failed from 0x610D1FBC, alignment 0
Pool: Processor Free: 3662516 Cause: Memory fragmentation
Alternate Pool: None Free: 0 Cause: No Alternate pool
Please assist me, if anybody can, in solving this problem
Configuration of AS5350 :
128 MB RAM
2 1xE1 ports
60 DSP
IOS - c5350-is-mz.123-4.T.bin
Here is connection schema of AS5350 :
2 E1 connected to the SI2000 telephone switch by ISDN and R2 digital.
2 E1 merged in multilink and connected through G.703 system to VoIP service provider.
There is no echo cancellation on voice ports and codecs are G.729A. Also modem passthrough is on in dialpeers.
Here I am giving a part of config:
resource-pool disable
clock timezone SAMT 4
clock summer-time SAMST recurring last Sun Mar 2:00 last Sun Oct 3:00
tdm clock priority 10 2/1
spe country russia
spe default-firmware spe-firmware-1
aaa new-model
aaa session-id common
ip subnet-zero
no ip source-route
ip cef
no ip domain lookup
isdn switch-type primary-net5
voice call send-alert
voice service voip
fax protocol t38 ls-redundancy 0 hs-redundancy 0 fallback none
h323
h245 tunnel disable
h245 caps mode restricted
modem passthrough nse codec g711alaw redundancy
controller E1 2/0
channel-group 0 timeslots 1-31
controller E1 2/1
framing NO-CRC4
pri-group timeslots 1-31
controller E1 3/0
framing NO-CRC4
ds0-group 0 timeslots 1-15,17-31 type r2-digital r2-compelled
cas-custom 0
country easteurope
alert-wait-time 30
dnis-digits min 3 max 20
timer interdigit incoming 3000
controller E1 3/1
interface Serial2/1:15
no ip address
isdn incoming-voice modem
isdn send-alerting
isdn sending-complete
no cdp enable
voice-port 2/1:D
cptone RU
voice-port 3/0:0
compand-type a-law
cptone RU
dial-peer voice 3 voip
huntstop
preference 1
destination-pattern 8..........
progress_ind setup enable 3
progress_ind progress enable 8
progress_ind connect enable 8
translate-outgoing calling 200
session target ras
tech-prefix 55#
fax rate disable
no vad
11-02-2004 01:14 PM
I guess you have to upgrade to the Cisco IOS ver 12.3.3 and this will fix u r problem
