Problem with VIC2-2BRI-NT/TE
BABARCHE
I have a 1760 router with a VIC2-2BRI-NT/TE.
In France, we are in TE mode. The Network Terminal is provider property. So I connect my routeur to this NT.
When I start the router, the D channel comes up so I can start a call (I used csim start command). Everything is alright. At then end of the call, the D channel falls (why?). After that, I'm not able to make an outside call. The D channel don't want to come up.
If I try an incoming call, then the D channel comes up and so an outise call is owrking too.
After the call, the D channel falls again so it is impossible to recall.
The ios version is : 12.3.8T
I tried to make a outside call using a data BRI WIC (WIC-1B-S/T=) and it is working well. The D channel falls after a call but comes up when I try to make an outside call.
Does someone have an idea about this VIC2-2BRI-NT/TE problem ??
It's really strange ....
I join the conf to this post and also the log.
Thanx !
Bye
Bastien.
same problem, in spain.
