Problem with XP SP2 and associating devices
degg
I am running CCM 3.3(3), 2000.2.6sr3. I just upgraded my laptop to XP SP2, and now I get an error. When I go to Global directory, select a user, and go to the Device Association page I get an error on the /ccmadmin/userprefsphones.asp. I cant search for devices to add, un-associate a device, or click on any buttons. the error is in different line numbers depending on what I try to click on, but it always comes up as a 'Permission Denied' error.
I have turned off the Windows firewall, set my security for Internet and Local Intranet to low, reinstalled the latest version of Java, and checked all my internet settings to allow everything.
Does anyone have any idea what setting is changed by SP2 to cause this error? or is it an error on my CCM? everything was working fine until I applied SP2. This problem doesnt happen if I use a non-SP2 computer.
alan-white
I have run into this same issue with the only apparent fix being to uninstall xp sp2.
I was afraid that would be the only answer, I guess I'll just uninstall it.
