Problems with dial peer and meet me numbers,
jhess
I've got an analog phone hooked up to my 2651XM and when I try to dial my Meet-Me number that has been created on an IP phone I hear the beep on the IP Phone indicating that someone has joined, but on my analog phone I just get a busy signel... Anyone else have this issue?
Here are my dial peer setting...
dial-peer voice 5000 voip
preference 1
destination-pattern 50..
session target ipv4:192.168.1.124
dtmf-relay h245-alphanumeric
any help would be great.
JH
2 Accepted Solutions
Vance Krier
Level 4
Level 4
I'd guess you are just using CM as the conference resource and not using a hardware based conference bridge? CallManager only supports g.711 for software based conferencing. IOS gateways use G.729 by default. Try changing the codec under the dialpeer to 'codec g711ulaw'.
Good luck,
Vance
Try to create a voice class codec and apply to the dial-peer.
voice class codec 1
codec preference 1 g711ulaw
codec preferece 2 g729r8
codec preference 3 g729b38
dial-peer voice <> voip
voice-class codec 1
If there is any codec issue this will take care of it.
Radhika
Vance Krier
Level 4
Level 4
Good luck,
Vance
voice class codec 1
voice-class codec 1
Radhika
perfect!
That was it, thanks for your help.
Josh Hess
