problems with E&M connecting to ccme
barbosa
Beginner
Beginner
remote sites with Cisco 1760V connect via analog E&M to a central site with CCME and when the ip phone ring and I off-hook,it take about 4 seconds for audio start talking.
If the call is made by CCME to the analog E&M, there is no problems with audio.
If anybody already have this kind of problem please let me know the solution.
Thanks.
smalkeric
Frequent Contributor
Using Analog E&M with CCME should not create such problem. Have a look at the Administration guide for CCME. It might guide on how to configure the analog ports.
http://www.cisco.com/en/US/products/sw/iosswrel/ps5012/products_feature_guide_book09186a00801812e4.html
dgahm
Collaborator
Collaborator
Are you set for H323 fast start? That is the default, but if you need to set it:
voice service voip
h323
call start fast
Also make sure you have this global command:
voice rtp send-rcv
This connects RTP streams immediately.
Thanks for your help.
It was the voice rtp send-rcv command that was missing in my configuration.
Recognize Your Peers
