07-31-2012 05:20 PM - edited 03-13-2019 07:56 PM
I've been reading a lot of documentation and going through various posts and pages for a few hours now, and just want to make sure I have the general idea right (if at all).
Basically, I have an Cisco 2900 router acting as a gateway for an VOIP network (using Cisco 8945 phones) at a medium business. I'd like to have incoming customer support calls automatically routed to the correct customer service representative based on information in an external database.
Here is my current thinking, based on what I've read. I don't know if this is accurate or not, so I'd really appreciate some clarification/help.
Does that general flow make sense? Is there a different, or preferred, way to accomplish the same thing?
Thanks in advance.
07-31-2012 05:45 PM
CUCM, doesn't run on ISRs, that's CME.
CUCM runs on MCS 78XX or UC on UCS.
It doesn't seem you can use UAS with CME
Table 1. Product Specifications
You would need to either use UCCX or to TCL scripting.
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
08-01-2012 10:27 AM
Thank you.
From the perspective of someone entirely new to this, it's just a bit difficult for me to navigate the sea of acronyms and changing names. Like CUCM/Unified Communications Manager versus CME/Unified Communications Manager Express/CallManager Express/ITS/IOS Telephony Services versus UCCX/Unified Contact Center Express and several others. So I really appriciate your help.
But I think I'm developing a more clear picture.
From the looks of things, what this company really needs then is Unified CCX Enhanced. Since we'd be creating a support contact center, UCCX makes sense, anyway. And UCCX Enhanced allows for custom Java extensions.
So the new, hopefully more accurate, workflow would be:
Does that make sense? Or, for step four, does the UCCX connect the call itself? (maybe I'm making an arbitrary distinction there).
Also - what are, in general, the hardware requirements for the UCCX? Is it really just as simple as installing VMWare ESXi 4.0 on a standard box/server and loading the UCCX image into the hypervisor?
Thanks again!
08-01-2012 04:26 AM
Yes, these things are doable, however they do require significant investment in products, and/or development time.
One way to reduce cost is to use CME on the router, then as Java said, some TCL/IVR scripts. Also possible to use CUE scripts, with the advanced IVR license.
In any case if you never did these things before, you will have to engage an expereince consultant for Contact Center markets.
08-01-2012 10:50 AM
Also if you are keen on CME, be aware that UCCX 9.0 upwards doesn't support CME anymore, so you are backing into a corner by selecting that deployment.
08-01-2012 11:25 AM
Well... That does add a wrinkle to things, doesn't it?
The C2900 ISR has already been purchased, which only supports CME it seems.
Going with the UCCX route, then, would require that we license the old 8.5 version. Aside from the incompatability problem, UCCX makes the most sense to me. But, that's not upgrade safe.
So. I suppose another question would be: Is there scriptable (Java, I'd guess) IVR funcitonality as a part of CME, or is a seperate license and seperate server required?
I double checked the version - we have UCCE 8.5, which supposedly supports CME.
Message was edited by: Kyle Lowry
