09-01-2017 04:33 AM - edited 03-13-2019 10:01 PM
Hello to everybody,
I have an issue with a CUBE [Cisco 2901- IOS 15.5(1)T2], the system (CUCM 11 and CUBE) works fine using an internet link to ISP "A"but when the CUBE uses another ISP "B" the system is unable to make outgoing calls (direct to PSTN) but can manage well incoming calls.
During debugging I see the CUBE stopping work at 100 Trying message, after this appears a "SIP 404 Not Found" message with Q.850=cause 3 (no route to destination).
What may be the problem?
I can add that the ISP "B" has not a constant throughput, I mean if I try doing upstream udp traffic I see a systematic holes each two seconds (see the image "upstream.jpg")
Below the debugging:
INVITE sip:xxxxx@172.27.199.62:5060 SIP/2.0
Via: SIP/2.0/TCP 172.27.199.11:5060;branch=z9hG4bKf02035fdfff1
From: "Pippo" <sip:sip:xxxxx@172.27.199.11>;tag=271417~4aca1d00-fcbd-60df-8ac5-ac9f97ba2d7d-27379310
To: <sip:sip:xxxxx@172.27.199.62>
Date: Tue, 06 Jun 2017 06:07:52 GMT
Call-ID: 781c7180-936146b8-d879-bc71bac@172.27.199.11
Supported: timer,resource-priority,replaces
Min-SE: 1800
User-Agent: Cisco-CUCM11.0
Allow: INVITE, OPTIONS, INFO, BYE, CANCEL, ACK, PRACK, UPDATE, REFER, SUBSCRIBE, NOTIFY
CSeq: 101 INVITE
Expires: 180
Allow-Events: presence, kpml
Supported: X-cisco-srtp-fallback,X-cisco-original-called
Call-Info: <sip:172.27.199.11:5060>;method="NOTIFY;Event=telephone-event;Duration=500"
Call-Info: <urn:x-cisco-remotecc:callinfo>;x-cisco-video-traffic-class=DESKTOP
Session-ID: 386b47ae9820477cbeb100deaa271410;remote=00000000000000000000000000000000
Cisco-Guid: 2015129984-0000065536-0000000441-0197598124
Session-Expires: 1800
P-Asserted-Identity: "Pippo" <sip:sip:xxxxx@172.27.199.11>
Remote-Party-ID: "Pippo" <sip:sip:xxxxx@172.27.199.11>;party=calling;screen=yes;privacy=off
Contact: <sip:sip:xxxxx@172.27.199.11:5060;transport=tcp>
Max-Forwards: 69
Content-Length: 0
*Jun 6 05:56:35.255: //11765/781C71800000/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 100 Trying
Date: Tue, 06 Jun 2017 05:56:35 GMT
CSeq: 101 INVITE
Allow-Events: telephone-event
Server: Cisco-SIPGateway/IOS-15.5.1.T2
Content-Length: 0
*Jun 6 05:56:35.259: //11765/781C71800000/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 404 Not Found
To: <sip:sip:xxxxx@172.27.199.62>;tag=1C03C958-3C5
CSeq: 101 INVITE
Reason: Q.850;cause=3
Content-Length: 0
*Jun 6 05:56:35.263: //11765/781C71800000/SIP/Msg/ccsipDisplayMsg:
Received:
ACK sip:sip:xxxxx@172.27.199.62:5060 SIP/2.0
Max-Forwards: 70
CSeq: 101 ACK
Content-Length: 0
Below the Dial peer configuration
dial-peer voice 2 voip
description in/outgoing ITSP
destination-pattern [0,1,3,8].T
session protocol sipv2
session target sip-server
voice-class codec 1
voice-class sip early-offer forced
dtmf-relay rtp-nte
fax-relay ecm disable
fax protocol t38 version 0 ls-redundancy 1 hs-redundancy 1 fallback pass-through g711alaw
no vad
dial-peer voice 10 voip
description to CUCM
destination-pattern xxxx..
session target ipv4:172.27.199.11
no voice-class sip session refresh
dtmf-relay rtp-nte
codec g711ulaw
no vad
Thanks in advance
Ciro
02-22-2018 07:24 PM
Hi, Did you get this issue resolved yet? If so could you share it with me please.
Thanks, Khanal
