Question about CPU load and Memory usage..
quake3bak
Beginner
Beginner
Hi. I'm a network engineer of South Korea.
I am facing an issue with DMP 4400.
I made some web page to publish the DMP 4400, but it's loading was so slow.
I don't know why it slows, but it can be because of memory or cpu.
So, I need to check CPU and Memory Usage...
is there anyone knows checking CPU and Memory Usage command?
I searched some documents and web site's include Cisco's but, I couldn't find out.
Nicolas Fournier
Hi Jinsung,
This should give you the memory usage on the device:
https://:@:7777/get_param?p=sinfo.memory
This should I believe give you the CPU:
https://:@:7777/get_param?p=sinfo.load
Nicolas
Nicolas Fournier
Hi Jinsung,
Nicolas
Recognize Your Peers
