Re-Send Cisco Spark invite to an external participant
rmrehders
Beginner
Beginner
looking for suggestions on a process or means to re-send the email Cisco Spark invite to an external participant.
Email invites can get lost, filtered or otherwise fail to be accepted.
However, once an invitation has been sent it appears that the ID is remembered and the host is unable to create a new 1:1 room with the external participant.
Any insight is appreciated.
Suggest you try Cisco Spark Support, if you can't get your answer there, you can submit a feedback request from within the app.
Recognize Your Peers
