receive ISDN call en-bloc
Istvan Balla
is there a way to configure ISR4300 SIP gw that has 1 ISDN PRI E1 to receive the called number en-bloc ( ENBLOC ) from PSTN provider instead of overlapping 1by1?
must provider agree in that if my configuration is ENBLOC, they send whole DNIS in SETUP to my router?
Manish Gogna
Hi Istvan,
Cisco routers can work in both Enbloc and Overlap modes as explained in the following doc
http://www.cisco.com/c/en/us/support/docs/dial-access/dial-on-demand-routing-ddr/23382-isdn-overlap-prob.html
You can either check with your Telco if they can send the DNIS as per your requirement, else you always have the option to configure your gateway accordingly.
Manish
