Recommended IOS for PRI gateway with CM 3.1(2c)?
jhinton
Level 4
Level 4
Given that IOS 12.2(2)XN is the version of IOS tested with CM 3.1(2c) in the release notes, but isn't yet released, what is the recommended version for a 3600 H.323 gateway bringing in PRI E1?
5 Replies 5
mdury
If you are Using a Unity and you want Ringback on Transfer, you should use 12.2.3
12.2.3 also has Progress Tones.
Does 12.2.3 have many issues? Sounds like it may have some Unity advantages which might make it superior to 12.1.5 YD3 which we've been using in conjunction with CallManager 3.1.2c on a 2600?
F C Wood
fc@wood.org
Chief Network Architect
Aggie.com L P d/b/a
The Wood Organization
We have been using 12.2.3 Mainly on Vg200's, strictly for voice. It seems to work the best for us
mderriennic
I'm going to install the same hardware. Can you give be any feedback about the IOS version you installed. Can you send me the conf ?
Marc DERRIENNIC
Technical Account Manager
marc_derriennic@arca-network.com
cstewart
Are you wanting to run SRST?
