RightFax intergration with Cisco IPT
dtangent
In a single site deployment, assuming that I have a set of DIDs for faxing only, is it possible to cross-connect RightFax server straight into an IOS gateway with either an analog (VIC-2FXS) or digital interface (VWIC-1MFT-T1) so that all fax calls coming into the IOS gateway's PRI will be routed straight to RightFax?
I have not been able to get a consensus as to whether this will work or not. Opinions differ by the gateway protocol (MGCP vs H322) or the type of interface (digital vs analog).
5 Replies 5
Daniel Baum
I have to assume some here, but the h.323 router can interconnect the PSTN to the Rightfax server either with FXS or T1. I have see some issues depending if super g3 is being used or just standard old fax machines. If SuperG3, you'll have to consider MGCP and fax pass-thru.
Please see this general guide for Cisco FAX services to assist in what is right for your project:
http://www.cisco.com/en/US/products/sw/iosswrel/ps1839/products_feature_guide_chapter09186a00800b5dcb.html#wp433042
For a quick potential fix, see the default fax method since Cisco IOS release 11.3:
http://www.cisco.com/en/US/products/sw/iosswrel/ps1839/products_feature_guide_chapter09186a00801446f0.html
If you think you may have SuperG3 faxing, let me know and I'll forward the pass-thru information.
Dan
Dan,
Can you not configure the router as an MGCP gateway, and configure CCM for fax pass-through. Since the fax has a different set of DIDs, all we have to do is pass the DIDs to the RightFax server. VIC-2E&M or maybe VIC-2FXO-M1 for analog, or VWIC-1MFT for digital to RightFax?
Topology:
Single site deployment (no faxing over IP really)
RightFax server ------ Cisco 3745 (MGCP gateway) ------ PRI to PSTN.
This will work perfectly. I have setup many customers in just the way you described and it works perfectly. Disable fax/modem passthru on the gateways for best results...
-jjf-
Josef,
Thanks for the confirmation. Did you use analog or digital trunk to perform the cross-connect? Also, I am assuming you used a Brooktrout card on the RightFax server?
Yes. That will work.
With MGCP, I suggest you use pass-thru.
Here is a task list for the gateway:
Task 1:
Disable fax relay on the gateway (by doing at "config t" global):
"mgcp fax t.38 inhibit"
"no ccm-manager fax protocol cisco" (turns off cisco fax-relay)
Task 2:
Set Cisco fax pass-through (by doing at "config t" global):
"mgcp modem passthrough voip mode nse"
Task 3:
Specify codec type
"mgcp modem passthrough voip codec g711ulaw"
Dan
