09-21-2003 10:28 AM - edited 03-13-2019 01:42 AM
In an ITS system, does anyone know where to get a set of ring tones to make available via TFTP, such as I think Call Manager has 24 that you can start with, without having to build your own?
Jerry Craven
09-23-2003 12:32 AM
you have to build an xml file known as ringlist.xml and the phone will request it form the tftp server. The rinlist.xml file should have an ordered list of the ringers and the names of the ringers should correspond to .au files encoded in g711ulaw.
09-23-2003 02:52 AM
I have successfully done this and nopw have many rings. Only small issue is that the 7940/60 have Chirp1 & Chirp2 by default(On phone) 7905 only has Chirp1. Does anyone know how to get Chirp2 as an entry on 7905 and where I can get file from (Cannot get it from phone)
