193
Highlighted
Beginner
Route-list causing problems with MGCP
Folks,
I have callmanager 4.0(2a) and everytime i make a change to the route-list (add more route-groups for failover), the change does not happen, not only that, i can not even make phone calls through primary router-group.
I tried resetting the route-list and the gateway from callamanger (MGCP). No luck
If i reboot the routers (gateway) everthing works fine? any ideas?
i am downloading the configuration from callmanager using ccm config server command, anything i need?
here is the config:
boot-start-marker
boot system flash
boot system flash:c3745-ipvoice-mz.123-8.T4.bin
boot-end-marker
card type t1 1 1
card type t1 2 1
logging buffered 131072 informational
no logging console
enable secret xxxx/
no network-clock-participate slot 1
no network-clock-participate slot 2
no network-clock-participate aim 0
no network-clock-participate aim 1
no aaa new-model
ip subnet-zero
ip cef
no ip domain lookup
ip domain name northgrum.com
no ftp-server write-enable
isdn switch-type primary-dms100
voice-card 1
no dspfarm
dsp services dspfarm
voice-card 2
no dspfarm
ccm-manager fallback-mgcp
ccm-manager redundant-host 10.209.7.10
ccm-manager mgcp
ccm-manager music-on-hold
ccm-manager config server 10.209.7.11
ccm-manager config
controller T1 1/0
shutdown
framing esf
linecode b8zs
pri-group timeslots 1-24 service mgcp
controller T1 1/1
framing esf
linecode b8zs
controller T1 2/0
framing sf
linecode ami
controller T1 2/1
framing sf
linecode ami
interface FastEthernet0/0
ip address 10.209.7.9 255.255.255.192
speed 100
full-duplex
interface FastEthernet0/1
no ip address
duplex auto
speed auto
interface Serial1/0:23
no ip address
no logging event link-status
isdn switch-type primary-ni
isdn incoming-voice voice
isdn bind-l3 ccm-manager
no cdp enable
interface Serial1/1:23
no ip address
no cdp enable
ip classless
ip route 0.0.0.0 0.0.0.0 10.209.7.1
no ip http server
control-plane
call application alternate DEFAULT
voice-port 1/0:23
voice-port 1/1:23
mgcp
mgcp call-agent 10.209.7.11 2427 service-type mgcp version 0.1
mgcp dtmf-relay voip codec all mode out-of-band
mgcp rtp unreachable timeout 1000 action notify
mgcp modem passthrough voip mode nse
mgcp package-capability rtp-package
no mgcp package-capability res-package
mgcp package-capability sst-package
no mgcp package-capability fxr-package
no mgcp timer receive-rtcp
mgcp sdp simple
mgcp fax t38 inhibit
no mgcp explicit hookstate
mgcp rtp payload-type g726r16 static
mgcp profile default
sccp local FastEthernet0/0
sccp ccm 10.209.7.11 identifier 1 version 4.0
sccp ccm 10.209.7.10 identifier 2 version 4.0
sccp ip precedence 3
sccp
sccp ccm group 990
associate ccm 1 priority 1
associate ccm 2 priority 2
associate profile 7 register CFB_10.209.7.9
associate profile 6 register MTP_10.209.7.9
keepalive retries 5
switchback method immediate
switchback interval 15
4 REPLIES 4
Highlighted
Contributor
Could you please use the trace function in the callmanager to isolate the problem .
Have a look at the following document
http://www.cisco.com/en/US/products/sw/voicesw/ps556/prod_troubleshooting_guide_chapter09186a00801eaf9f.html
Highlighted
You might be able to avoid a total reboot of the gateway router by doing a 'ccm config check reset' command from the gateway, it forces it to sync up with the CM, and a 'sh ccm' will show you your download config count increasing. I don't know why it would behave like this in the first place, but I have found this reset from the router to help a lot of weird things.
Mary Beth
Highlighted
I have the same CCM version and using 3745 gateways and I have not looked into to close, yet but I do know if you do a "NO MGCP" then MGCP from the global configuration it will synch back up after a 5-8 seconds.
I know what you mean, if you change parameters within side the Route List with the Route Groups like stripping digits or adding or even adding another RG this happens. This is also weird, if you add other Line Groups to the VoiceMail hunt list it does almost the same thing. You cannot access VM at all unless you take away the Route Pattern pointing to the VM-Hun List reboot the Publisher and then add it back in once the Pub is back online.
Highlighted
Beginner
I have the same problem.
When i have it, i just make an inbound call towards the pri (which still works fine). After that, outbound calls from the IP Phones work again.
Pretty strange all of this, is it a known bug or are we all missing something ?
Content for Community-Ad
