08-21-2006 02:14 AM - edited 03-15-2019 04:27 AM
I need a route pattern for
8XXXX, but needs to exclude the following ranges;
87000 ? 87199,
88470 ? 88519,
88520 ? 88569
I am a bit stuck, and don't want to enter loads it, can it be done with 1?
08-21-2006 04:30 AM
The easiest way would be to create these RPs, and put them as blocking RPs, or depending on what you want to do with them put in a seperate partition.
87[0-1]XX
884[7-9]X
885[0-1]X
885[2-6]X
HTH,
Chris
08-22-2006 02:58 AM
I have an inter cluster trunk to another callmanager, the
Range on CM A =
87000 -87199,
88470 -88519,
88520 -88569
the rest of 8XXXX needs to be sent out of the trunk
08-22-2006 05:13 AM
All you need then is the 8XXXX route pattern pointing to CM B. If phone on CM A dials any extesnion registered with CM A (granted it has access to it's partition) it will be more explicit match. If there is no DN matching on CM 1 then the route pattern will be used, again assuming it's partition is listed in the phone's CSS.
HTH, please rate all posts!
Chris
