Running Call Manager on DL360
MagellanTX
I apologize if this question has been asked already but how do I install Call Manager on a Compaq DL360? I don't have any 380's here and the operating system CD keeps telling me that the hardware is not supported. I've seen them run before on a DL360 but never installed one myself.
Thanks!!!
thisisshanky
Level 11
Level 11
You have to order separate CDROm kits for the 360s as the SCSI drivers for the HD will not be present in the CDs that you have(which are for MCS probably)
If this is for lab, you can install Windows separately, apply a registry hack and then install Callmanager from there.
Sankar Nair
UC Solutions Architect
Pacific Northwest | CDW
CCIE Collaboration #17135 Emeritus
Interested in building a test callmanager system for my home lab.
Any details on the registry modifications I would need to make to get Callmanager to load.
Again, this is strictly for a home lab.
thanks
Check out www.ccmstuff.org. Scroll all the way down. There is a link to the whole procedure.
Sankar Nair
